charles1961
Thread starter- Joined
- Dec 9, 2012
- 98
Re: stringer questions
sorry i did not post any newer pics yet. i was going to wait until i get some more of it cleaned out, so the pics show up better.thanks for the info of it could be either the stringers or the bulkheads being continuous.
Based on the pix you've posted, it's extremely hard to tell stringers (running bow to transom) from bulkheads (port to starboard).....
Try to get an area cleaned out that shows 6-8 compartments (separated by the stringers &/or bulkheads) bare down to the little bit of stringer or bulkhead (1" +/- you said you're leaving) and cleaned of foam exposing a bare hull. Similar to what WOG posted earlier:
This ^^^ looks like continuous bulkheads & possibly continuous stringers running thru notches cut out of the bottom of the bulkheads.
IMHO, you need to figure out exactly how the boat was put together originally, and try to replicate the stringer & bulkhead layout. Each boat & boat maker designs & builds boats to meet their goals, either the stringers or bulkheads can be continuous, and meet those goals.
A marine engineer designed it's structure, and as a system w/ hull, bulkheads, stringers, deck, fiberglass work & foam all working together.
