Re: Stringer question and opinions on it pls....
Thanks to all the experts who have contributed to my thread, i haven't started on my boat yet, i'm in the process of finishing up my shop to work on it. when i get to the point, i will post pics of the progress of the restore. I think i'm gonna need all the help i can get. Since this will be a winter project and if i do decide to encase the stringers in glass, to install them into the boat, is it a better choice to use peanut butter to glue in the stringers or to use PL? i was reading PL tends to bubble causing air pockets. Anyone know what would be cold weather combination of resin and hardner? My boat was made using Poly, although most people on here use epoxy. I was told that epoxy is stronger but doesn't last as long as poly does. Is there any truth to this? I was told use epoxy for gluing and poly for glassing. I'd rather stick with one or the other.
I'd also would appreciate someone sending me a link on how to measure accurately make a template for new stringers, in other words, if there were no stringers for templates. I saw a guy using stakes to get the different depths and contours then use the "connect - the - dot" method for a rough template, i understand that, but how do you determine the correct height and contours of the stringer and bulkheads to the hull? I hope i used the correct terms, if not forgive me, new to all this. I was also told that you don't install the stringers directly on the hull, use something like little pieces of foam board to provide a spacing to keep from getting hard spots on the hull, is this true also?
Thanks again,
BV
