Stray part identification. 1978 b4 85hp.
dnpowers
What is this and where is it supposed to be? I found it stuck to my shift rod (its magnetic) in my lower unit. Thanks.
wrench 3
Re: Stray part identification. 1978 b4 85hp.
It's a magnet designed to pick up any metal filings floating around in the oil and keep them out of the way. They're dropped in loose from the top but I'll have to check tomorrow to see were yours is supposed to be.
dnpowers
Thank you sir. I was worried for a bit on that one. I couldn't find it on any schematics.
Those were used in the 66 through 68 100 HP electric shift lower units.----They were also used in the electric shift sterndrives.----------Some one added that to your lower unit to act as a filter for metal parts.-A very good idea.
Faztbullet
Your unit came with it from factory it is part #380375....
boobie
Go to shop.evinrude.com, look up your motor, go to gear case and you'll find it.
