wordmaster
Thread starter- Joined
- Sep 14, 2002
- 27
I have a pontoon with a 79 115 hp Johnson V4 on it. I took the boat out and was cruising along at close to top speed, motor running sweet and smooth. Suddenly it sounded like one will when it runs out of gas, spluttering and missing. I limped back to the dock, brought it home and pulled the plugs.<br /><br />I have not had the boat long and have put a total of 10 hours or so on it with the motor running fine. The plugs were two looked like they were a bit old, one looked oil fouled, and the other looked like it had been hit with a hammer.<br /><br />The one that was smashed was filled with metal particles and the electrode was dead against the tip. I looked in the cylinder and the piston was bright and clean, other pistons were black, but cleaned right up with solvent spray. The piston showed no sign of a crack or hole from hitting the spark plug.<br /><br />Go to http://www.perryelrod.com/spark/sprk.html and take a look at this plug. If anyone can be of help and tell me what is going on, I would very much appreciate it. I have seen many plugs in many different conditions, but have never seen anything like this. By the way, this plug was the same number as the other three, ie., Champion QL77JC4. My manual calls for L77J4 and I am not sure what the extra "Q" and "C" mean on these plugs. Help??<br /><br />Thank you for your answers. I don't have a compression guage, so I put new plugs in and cranked it with muffs. Removing the wire of the plug in the pictures made no difference in the running. Removing the wire from any of the other three would cause it to run worse.<br /><br />After running a few minutes, I pulled the plug in question and it was full of water. Is this a head gasket? A head gasket and a ring? Considering the way the plug was bent in, can anyone give me any ideas on what it might need and what it might cost or if it is worth fixing? BTW, it looks like carbon fouling in the pic, but it was actually metal particles in the plug.
