Stingray 180rx water leak
corvettedude1
Hello everyone. I have a 2007 stingray 180rx with a 3.0 volvo penta and a sx a outdrive. I seem to have a mystery water leak. It's always taken on a small amount of water but very small. Like less than half a cup on a full day of boating. But last trip out it took on alot. The large space under the engine was completely full. At least a few gallons. My bilge pump could've took care of it but I never turned it on because I had no clue it was back there until the trip was over. So the next day I ran it on the muffs and saw no leaks whatsoever so I assumed it wasn't coming from there. So when I got the chance I took it to the ramp which was empty and left it sitting on the trailer back into the water for hour to see if it was leaking in from the hull somewhere and nothing came in. So since the ramp was empty after that hour I let it idle for at 30 to 35 minutes to check again for motor leaks and nothing. Took it home and fill the blige with water on purpose and parked it in the garage on dry concrete to see if any leaked out. After a couple days it has leaked nothing. Any ideas on where to start? Any possible places this mystery leak could be coming from? Thanks for any suggestions although this is a new account you all have been helpful for years I can't seem to access my old account.
alldodge
Welcome
Need to put a float switch on your bilge pump so it turns on automatically
Other than putting water in the bilge (I wouldn't do that) to see if it leaks out your testing is good. Only way to find the leak is in the water. Might have something to do when water pressure builds while running on plane
corvettedude1
Thanks for the tips. You were helpful with another question i had years ago, i remeber the picture of the battleship lol. I guess out on the water is the only way I'll eventually find the leak. Is there any common places for it to come in while underway?
with the boat in the water, the motor running. look for a leak from the raw water pump, the circulating pump, or other locations.
use a flashlight, a mirror on a stick, or even your cell phone in selfie mode to look where you cant get your head.
