KathyD19
Thread starter- Joined
- Jul 17, 2012
- 369
When I bought this the seller said it doesn't tilt. I thought all boat motors tilt up so I was surprised at that, but of course, I'm a newbie so I'm probably wrong!
Any hint on what the latch/release looks like?Reread post #2Hummm ... I was under the impression that OB's should run unlocked unless in reverse ... thinking it would cause damage to the transom if hard rock bottom is hit at WOT.
After reading some transom horror stories I think I"ll stick with my method of running my OB in the release mode when in forward. LOLReread post #2
or if it's supposed to hook to the pin that I've circled in green? If it's supposed to hook to the flat bar, isn't the hook on the wrong side of it...meaning shouldn't it be on the side of the bar closest to the boat rather than the side closest to the shaft? If it is on the wrong side, I imagine I'll have to take the motor off the boat in order to access it and reposition it, although I have no idea why it'd be on the wrong side in the first place since it doesn't have any bends or damage to it as if someone forced it to the wrong side. This is such a simple thing and it frustrates me!
While on the subject, you are supposed to run it in the latched down position. Release it to tilt. Now, you are going to ask, what if I hit something? Not to fear, it will automatically unlock and tilt up. That's what that big spring is for on the rear of the swivel bracket. If you don't believe it, lock it down and hunker down and grab hold of the lower unit. Give a mighty yank to the rear, and it will make a god-awful bang and come on up. The bang is the automatic release doing it's thing and is totally harmless.
