MajBach
Thread starter- Joined
- Jun 21, 2003
- 564
Hi All!! This is a hard one to do a search on and even my shop manual doesn?t cover it and I don?t want to proceed to take anything apart without at least a diagram. My Honda 90hp has been slowly been getting harder to steer ? nothing to do with the trim. Just out of the water, there is a lot of resistance in the steering wheel. Used to be, I could swing the motor left to right by hand ? even when vertical ? just by pushing on the cowling. Now, even with the motor trailered right up, gravity won?t even pull it to one side. Obviously, first thing I did was grease the two nipples ? as I do every year, but ZERO difference. I applied enough grease to expel the grease inside ? which was quite dark ? through the crack in the pivot joints. I then removed the control linkage from the push arm so that the motor was ?free? from the steering wheel and you could practically swing it side to side with a strong wind. So I then proceeded to remove the nut on the driver side of the motor that attaches the push arm from the steering wheel ? sort of looks like a brake line type fitting. Ok, so when I try an pull it apart to separate it from the motor, I can only go about 2/3s the way as I?ve run out room to pull it any further but what comes out from inside the pivot shaft of the motor mount is a large tube with a smaller diameter rod inside it. This smaller rod slides in and out of the larger as the wheel is turned. Anyone whose worked on this knows what I am talking about. Both shafts looked shiny but had only a thick film of old grease on them , requiring a rag and several passes to remove, and not an even coat either. There was no evidence of fresh grease. Even when I cleaned the shafts off and reinserted them and pulled back out, they looked the same. I did this several times. I then manually greased each rod. Surprisingly, once reassembled, it seemed slightly stiffer at the wheel. So whats my next step? And where is all the grease I am pumping through the nipples going aside from through the cracks. Anyone know where I can find a schematic of the motor mount?
Thanks a HEAP in advance.
