stern drive question
simes2001
I have a 1993 bayliner cuddy. when im done using the boat and i lift the sterndrive the oil leaks into the engine compartment. how do i fix this?
possum2082
Re: stern drive question
are you sure it's sterndrive oil? engine oil? trim oil?
what do you have?
RogersJetboat454
Welcome to Iboats,
You should move your question (or have it moved by a Moderator) to the appropriate stern drive forum (most likely Mercruiser I/O) to get your question effectively answered (the Bayliner section is specific to ownership, hulls, etc). Please include the serial number of your engine, and model of the drive (alpha/bravo).
It is also important to include anything you have done to try to determine the cause of your leak, and any maintenance recently done to the drive (i.e. is the drive removed annually for inspection).
