Stereo wiring
beanz2166
I had two batteries somehow linked together with the stereo somehow wired into the battery. After a mechanic seeing how it was done he was worried about it being a hazard. He said that I could run off a single battery if I wanted. Today I removed all the shoddy wiring the extra cheap battery but now my stereo isn't wired in and I'm not sure how to do it. Any suggestions
dls322
Re: Stereo wiring
Red and yellow wires go to positive. Black goes to ground, the rest are all speaker wires (YES granted there are dimmer, power antenna, remote amp turn on....ect on higher end stereos) but you will be get a working stereo with hooking up those 3. Granted there are no blown fuses.
I prefer a dual battery setup myself.
beanz2166
Re: Stereo wiring
Yeah I think I do too. I have a switch off/1/2/all. But I'm confused on how to wire it all together safely. I'm going to make a diagram of what I got minus the stereo hopefully someone can help off that. Unfortunately stereo wires are both blue
beanz2166
Re: Stereo wiring
ok boat is a 1996 glastron gs215, with a 5.7 merc, the battery switch is a Perko (sorry thats all it says no model with it is this decent it came on the boat when I bought it) here is a drawing of how I think it should look if Im right where should I connect the stereo? if Im way off what am I missing?
Don S
Re: Stereo wiring
Here is a wiring diagram I did for another member. Second page show proper 2 battery wiring for a battery switch like you have. First page will give you a good idea of how things get wired.
Your red trim motor wire should go to the common terminal of the battery switch.
Wiring the stereo has to come from the helm fuse panel.
What you need to do is find the wires coming out of the stereo and getting the colors there. Both blue wires are probably what was added on to the stereo to reach the battery.
View attachment GW Wiring Diagrams.pdf
beanz2166
Re: Stereo wiring
thanks don last question on the back of the battery switch #1 says 6-32 DC and #2 says ignition protected. which one runs to the start battery?
Don S
Re: Stereo wiring
That is just information about the switch.
It's good for voltages between 6 and 32 Volts DC, and the ignition protected means it's sealed and can be used in the bilge area of a boat and will not blow you up.
beanz2166
Re: Stereo wiring
Well the stereo doesn't work yet. I tried various ways with the same luck. I was told tht the yellow wire was the memory wire and to run that directly to the battery while connecting the red wire to the battery switch , then I tried connecting both red and yellow directly to the battery and that didn't work either. I changed out the fuse on fhe radio as well. I think the radio itself is shot, maybe got wet at the mechanics.
Don S
Re: Stereo wiring
The yellow memory wire does need to go directly to a battery so it will remember your stations. The red wire is for power to the stereo, but you also need a ground wire (black) going to the negative bus bar or for your testing to the negative terminal of the battery.
The red and yellow wires go to the positive terminal of the battery for testing.
beanz2166
Re: Stereo wiring
Yup that's what I did and no dice. Last thought is the radio is shot
Ming15237
Re: Stereo wiring
This is why I am consistently reminded why this is such a great community we have here. Very few other web sites have people that are willing to do this type of work to help a fellow member!
beanz2166
Re: Stereo wiring
Finally I got the radio to work,y running everything directly into the battery then when I connect the yellow wire to the battery and the red wire to the House battery connection at the switch (#2) the radio works, as it should, BUT when I move the switch to #1 (my starter battery) the radio still works shouldnt the battery only work when the switch is on #2 or Both?
Don S
Re: Stereo wiring
With a 1-2-Both battery, you are only choosing which battery turns everything on. Not house or starting off separate batteries.
Look at the second page of the wiring diagram I posted above.
