Chevysolid
Thread starter- Joined
- Dec 27, 2008
- 47
Ok I already have a head unit and two speakers, and I am wanting to add some sound... (I don't plan on annoying everyone I come in contact with so bear with me if you hate those guys who let the whole lake hear their music, we have a cove area where alot of people sit and listen to music, much like a sand bar....and I am on a river some too... ;-) N E way...
I am setting up two skm10 Kicker subs, and four other 5-6" speakers to run off of a 2000w six channel amp. I currently have one marine battery in the boat and figure on adding another for the amp to run off of.
First question: On the battery there are four lines, two red, two black, as there are two posts for each.. .different that in a car.... are the smaller posts the "charging" posts or what?
Ideally I want to set it up so that both batteries are being charged by the alternator and only one is being used to power the amp... if it is drained then the other will still have power to start the boat.....
Without a toggle switch if possible....
second question: Has anyone done a similar set up and if so, what kind of play time should I expect of a decent size marine battery at moderate levels of volume
If it matters... engine is a 5.7LX, so I am thinking that the alternator should be enough to charge both batteries when needed.
Thanks
Thanks
