Stereo help please!!!
bruceb58
Honorary Supreme Mariner
Re: Stereo help please!!!
The ground that you used most likely is much too small to run 10-15 amps with the deck turned up.
Just for info, there is no way a deck takes 15 amps. More likely a bad ground vs a wire that couldn't supply the current. In any case, don't piggyback off a ground that goes to the gauge lights. Run a ground to the bus bar at the fuse block. Absolutely no need to run a ground back to the battery on a basic stereo unless you are running into a noise issue.
It'Most stereo guys use pretty heavy cable - like 0 or 2, not the 12 or 14 that your gauges are most likely wired with.
And this is because most stereo guys barely have a high school education. Come on...0 gauge wire? Give me a break.
But since I really don't care about the presets and the clock staying set I will just hook the red and yellow both into it and put the stereo power on a toggle switch.
Good idea. No problem connecting both wires together despite what others say.
dsiekman
Okay:rolleyes:...I realize there are diffent opinions here, but the question mentioned NOTHING about creating an obnoxiously loud system for the purpose of annoying fellow boaters, home owners, etc. Furthermore, the OP never said anything about going to a confined waterway. For all we know, he may be planning to play his stereo in the middle of the ocean. If that is the case, who cares how loud his radio is?
The issue, as it turns out, was a less than adequate wiring setup. This could be potentially dangerous regardless of how loud he wants to play his radio, or could cause other systems to malfunction or short out. Let's focus on the important issues. If people want to sound off (pun intended) about loud boats, stereos, leaf blowers, etc., start a new thread!
bruceb58
This could be potentially dangerous regardless of how loud he wants to play his radio!
Please explain how you think this could be in any way dangerous.
dsiekman
Sure.
Opt. A: Let's say whoever had the boat before him ran an undersized, unfused wire directly to the head unit. Said wire overheats, melts the insulation and shorts on something else causing a fire. Like I said in an earlier post, I had a similar thing happen to me as a kid. It burned up the fusable links (lucky it had them). Lots of smoke, and a little bit of flame. Had I not had the hood up, or if it had occured in a boat with the potential of gas fumes in the bilge, it could have been a significant problem.
Opt. B: The radio "sort of" works for some time. However, the power/ground problem has damaged other compontents connected inline. Let's say he's on the water when everything on that circuit goes. For fun, let's say the vhf was on the same power feed. Now he's stuck on the water with no communication. On a beautiful sunny day at your local lake, not a problem...20 miles offshore in a squal, you've got a little more of an issue.
I'm not trying to overcomplicate or dramatize the situation, but let's face it, when you are out on the water, you really want things done right. We don't know anything about the OP's boat or how he plans to use it.
Another perfect example...I've always been told the best practice is to doulble up your hose clamps. Will something fail if you don't? Probably not. If I did lose a clamp, would I be happier if there was a backup on that hose? You betcha!
infideltarget
Master Chief Petty Officer
FWIW...I suggested taking the ground to the battery for just that reason...noise. He mentioned adding an amp, and to avoid potential speaker damaging noise, I suggested a nice new fresh ground at the most secure point. Sure...he can put the yellow and red together and it *may* work just fine. And for someone with wiring knowledge, this wont be an issue. The OP obviously does not have this knowledge, so I suggested he take the safest route and run separate wires to avoid possible issues. AND depending on which deck he has, he may not be able to simply cut off the constant 12v to the mem circuit for the reason I stated...anti theft circuitry. If he kills the power every time to the mem circuit, he may have to input a code every single time he turns on the stereo. Wrong code more than 5 tries = dead stereo. SOME newer decks will cut the output after so many times of complete power loss even if you do enter the correct code. Then you have to remove the deck, and take it to a technician or send it back to the factory...along with proof of purchase...to get it reprogrammed. I was simply trying to allow the OP to avoid these headaches, and go the easiest route. But hey...I guess my barely adequate edumacashun had me going the wrong direction. OP...you do what you want, how you want. I'm done here.
Silverbullet555
Boy, this thread sure went sidways overnight.
To the OP, wire it up taking into account max loads, use fuses that will pop at the right time and do your wiring with the intention of adding to it in the future. Maybe for an amp, maybe for something else that draws current. Who knows what you will want to add, but I will tell you that if you want to add something down the road you will be kicking yourself for not running oversized wiring. Do you need 1/0 awg wire? Maybe not. I ran 1/0 in mine so it was built and there was no worry about capacity. In all reality, my system and the way I listen to it will never draw anything close to the capacity of the cabling, but that is exactly how I want it. Have a problem in your car, pull over and get out. Have a problem in your boat and it's not that easy.
Just dsiekman said. There is a reason we double clamp, carry two fire extinguishers, etc. You never know what can happen and it is better to be prepared.
Back to the OP, you now know what the main issue was. Notwithstanding other issues, run your wires, put it together and ennjoy your boat!
bruceb58
The noise that would be picked up would be noise caused by blower or an accessory. Hardly noise that could cause speaker damage.
If he kills the power every time to the mem circuit, he may have to input a code every single time he turns on the stereo. Wrong code more than 5 tries = dead stereo. SOME newer decks will cut the output after so many times of complete power loss even if you do enter the correct code..
If his radio requires a constant power, then he doesn't want this type of radio in a boat anyway since it will draw down the battery when sitting for a long period.
