Johnson 4-73 proper position to gap points
77manfred
I just replaced coils and condensers.
How do I find the correct position to set the gap of the points (.020 ?)
thanks
Manfred
Xcusme
Re: Johnson 4-73 proper position to gap points
Rotate crank shaft and align key way with points rub block (part that contacts the points cam). Using feeler guage, set point gap to .020. Rotate crank shaft 180 degrees, and again, align key way with rub block and set point gap.
77manfred
Xcusme.
Thank you. spark looks sort of punish but with a shot of ether I got it started.
Planing to replace spark plugs and wires and get new gaskets for the carb.
Impeller is not pumping either.
thank you very much
Manfred
tashasdaddy
NEVER use ether or any other starting fluid, use premixed fuel. these others burn too hot, and strip all lubrication off the motor.
Xcusme
Xcusme.
thank you very much
Manfred
Manfred, you mentioned that you replaced the coils....did you mount them properly? The coils should be mounted so that the coil bases sit flush with the mounting bosses on the armature plate.....make surface A flush with surface B (2 per coil). Just loosen coil mounting screws to make adjustments and tighten.
Take Tashasdaddy's good advice...loose the starting fluid. Use premixed fuel in a squirt bottle instead.
