Steering
zuma72
I just bought a 1986 cuddy cabin with a 140hp mercruiser. I took the boat out for the first time and it very hard to steer. Also, it dies when put in reverse. Any suggestions? When the motor in running, should I see any fluid moving in the power steering pump? Thanks!
Bt Doctur
Re: Steering
steering may be a tight steering cable .power steering or not ,the cable still must travel freely thru the guide tube. Stall while shifting is a sign of a bad ,worn shift cable. Looking into the pump you may see movement and you may not.
A new purchase should have included a test drive for at least an hour to make sure all system operate properly. Posting an engine serial number should get you the correct manual.
zuma72
Re: Steering
Can you tell me the replacement cable for a morse e300619 180in 3581 ? I can't find it anywhere thanks
