Steering Seized
misdeal
Have 120 HP Johnson out board,,been sitting for about a year now, just got it running but when i tried to turn the steering wheel back and forth the motor wont budge, tried shooting grease in the fittings, pb blaster on the rod, block of wood and hammer, was able to knock it one way then back but still cant turn the wheel, infact i may have stripped or broken the steering gear box as it now has to dead spots where it kinda spins/clicks the catches again,, any ideas on how to free up the steering ? is the steering box repairable ?
boobie
Re: Steering Seized
I don't know where you would find parts for the box. Sounds like you need a whole new system. About 2 yrs ago you could buy the whole kit for about $190.00. Shop around.
misdeal
Re: Steering Seized
thanks for the info,,gonna work on freeing up the motor first, then move on to the steering
wilde1j
Re: Steering Seized
If you disconnect the motor from the steering, you will likely find the motor isn't the problem, but it could be.
misdeal
Re: Steering Seized
disconnected motor from steering,,,motor turns back and forth with ease,,but now have the task of getting the rod out of the roll pin,,,
