stearing ona 66 evinrude spotfor 4v
mikehowe
ok i can figure out how to use my stearing arm drectly to my 1973 ebbintide bass boat so i can tile my motor becouse there is no place to hook my arm to keep it from moving if anyone has a answer please let me know i will get some pick of my boat stearing and motor in a few
mikehowe
Re: stearing ona 66 evinrude spotfor 4v
but as u can see in the pic my hookup is infront instead of strait out
tashasdaddy
show picture of the side where the cable comes from.
mikehowe
ok i got a fix where i can tilt my motor now it works better then my old set up
F_R
Honorary Supreme Mariner
You want to get yourself or somebody else killed? That Micky Mouse strap you have holding the outer cable housing has to go. NOW! Get a proper transom mount kit. They should be for sale here at iboats.
tashasdaddy
that is totally ridiculous. you need the TRANSOM SUPPORT MOUNT kit in the link.
mikehowe
the 4 inch thick bar will hold for now and the clevis i got fome the local boating shop so untell i have the extra cash it will work trust me me and my friend a combine weight of 500lbs stood on that bar and could not deflect it and the bracket is 22 gage cold bent steal so it's not moving no where eather
jimmbo
Where do you boat? I want to know so I can stay away. FR is right, that measly little clamp is not going to hold the cable for very long. When it let's go, and it will, I just hope you don't take any innocents with you.
