steaming hot water out pee hole
ace420ace
ok replaced impeller today but i couldn't get lower pump housing off of tube so only replaced impeller,gasket,big o ring and seals any tips or tricks for getting the lower unit back on?
thanks
ace420ace
damn just found out big o ring is for prop, what seals between top housing and metal plate?
quicktach
It doesn't sound like you have a problem yet. If in doubt, you could replace the impeller now and avoid a problem later. Also open the tstat casing and look for any crud or deposits and then clean out. Also check your water inlet screens for blockage. If you run in salt water you may also need to clean water passages.
