Well, you win some, and you lose some. Today started off hopeful as we headed to the lake and lit the match. Pressure built up correctly and we rolled Merrilee off the trailer and down in the water. For an engine and drive shaft that never gave us problems, the day was plagued with 2 universals disconnecting, and the engine not running smoothly. After Wednesday’s run we had tightened down most of the bolts and so the engine was stiff- apparently enough to make it run as shown in the video below.
We tried to venture away from the dock and it was abundantly clear that things were still not right and after trying to turn around (several forwards and reverses), I paddled the boat the 100 feet back to dock- a surprisingly easier feat than one might expect!
We were able to get the bilge pump tested, as well as steering on our very limited voyage, and we got to see the boat in the water with all of the name plate and woodwork that has been added. Also- given that it was an October day, we got to test that the heat in the boat worked. It did. Ah, modern day comforts…
Anyhow- I wish I was able to report more, but the fact that we really didn’t get it to run as desired basically shut down our entire day. Admitting defeat, we somberly loaded back on the trailer and looked forward to having it back in the shop to be able to fix things without the engine being blazing hot.
