stator to alternator
roffey
Need help. I suspect many have converted a 370 from stator to alternator. I was thinking I just had to follow the wires from the voltage regulator and just remove them and replace with the wires from the alternator. My problem is I see there is a wire that goes to a part on the starter motor, it?s not the solenoid. This part is connected to the starter. I can take pictures if need be.
Bt Doctur
Re: stator to alternator
post some pics, we`ll try and figure it out. the orange wire at the regulator is what you were supposed to connect to .That goes back to the battery
roffey
At work now, I will post some pictures tonight.
roffey
OK back at home now. There is a wire that goes from the solenoid to the starter (as it should). There is a part on top of the starter that has a wire coming from the voltage regulator. Have a look, please and thanks.PART.jpg
Bt Doctur
that plastic block is either a 90 or 110 amp fuse. everything looks normal there. the orange wire goes to the output post on the alt.
Here is a diagram edited and uploaded by DonS.
  • 470 wiring w alt.pdf
roffey
but it is connected to the voltage regulator. I traced the wire back to the regulator.
roffey
OK I think the diag is what I need, thanks... and thanks to DonS. I'm sure he has a smile on his face right now.
