static timing
chitownborn
on static timing do you remove the spark plugs or leave them in, its a 87 force 85 hp, i know to ground the spark plug wires but not quite sure on the plugs to leave in or remove, thanks
azlakes
Re: static timing
... hiya chi, not seeing anything about having to remove the plugs.
Static ignition timing:
An obsolete timing procedure carried out by rotating the engine until the timing marks are aligned and then connecting a test lamp or a voltmeter between the negative coil terminal and ground; when the points open, the test lamp lights up or the voltmeter registers battery voltage. The opposite is dynamic or stroboscopic ignition timing
