starting problem
bcoonie
I have a 1995 115 jhonson faststrike that sat for over two years . After removing all old fuel I could from tank and draining carb bowls , I also installed a new battery. I had the engine running , but when I went to the lake the engine would not fire the first time. Later at home I have tried starting engine. The only way it will fire is to spray starting fluid or fuel into the carbarators.Any ideas as to what the problem might be. bcoonie.
petryshyn
Re: starting problem
I think its time to clean the carbs and do a fuel system service/inspection.
