Starting Problem
Re: Starting Problem
Ayuh,...
Welcome Aboard,....
If you're expecting any answers,...
You might want to repost that in the default settings....
You're dealing with a bunch of old Salts who don't want to have to Squint to Help You....
chiefalen
Please do have the default setting, but what i did read is that your running the boat without water going to the drive.
5 seconds no more impeller in the drive is all it takes.
So now you got to check the impeller before you do anything, and than check the fuel system, and please go to the top of the forum and read the adults only links.
And then post again please.
Welcome aboard !
chiefalen
Appliance man knew enough never to run the drive without water going to it.
Yep same thing same result, after he cuts the trim sender wires.
Don S
Except the trim limit wires had absolutely nothing to do with the ignition system.
When the engine won't start, check to see if you have spark.
chiefalen
I bet Don you know where the short is where the trim is shorting it out.
How stupid of me i bet i would have made money if there was a wager and i bet on you.
You probably seen it before. Many times before i bet.
