Starting Merc 255MIE without throttle
legoman67
Well, we have run our mercruiser 255MIE on the ground twice now, both times we have had to have one guy playing with the throttle to get it going, then once its going we can slowly let off the throttle. The problem is in our boat we dont have idependant throttles(they are mixed with shift). I am wondering if a) the engine should be this way(maybe the mechanical choke needs adjustment) or B) if this is normal for starting a carbed engine, then how is it going to work in the boat? The boat has always had carbed engines, so it must have worked before.
1979 mercruiser 255MIE SN#4881081
here is a video of the latest run today.
http://www.youtube.com/watch?v=3QYMC76yodo&feature=channel
Re: Starting Merc 255MIE without throttle
Ayuh,...
I've never seen a controller that you can't push a button, or pull on something to Disengagethe Shifter, so you can use Just the Throttle....
Carbed motor most always need throttle motion to Start...
Don S
Post a picture of your shifter, I'm sure we can tell you how to get it into throttle only after seeing the control.
legoman67
Well i went out this morning and got it off the boat( a little tricky) and started to play with it pushing and pulling everything i could, and figured out you have to pull the whole lever out and it disenguages shift!!
Its an Morse M MT2
Thanks!
Don S
Put the shifter in neutral and pull the complete handle away from the control and move it forward for throttle only. When you come all the way back to neutral, it will automatically go back to throttle AND shift.
