I'm at wit's end.
The engine was starting then immediately dying, then I figured out the safety lanyard was off the little clip.
I put it back on (after I had checked fuses & the only relay I could find - by the fuel pump), but now the starter won't turn over & no clicking, etc..
It bench tested good so I figured the solenoid went bad & bought a new starter (the solenoid is attached to the starter).
Same results now.
Key on, everything lights up.
Start position: the fuel pump runs but (brand new) starter doesn't turn or click.
Battery is fully charged.
Wiring appears correct.
Same results now.
