blacksmith82
Thread starter- Joined
- Jun 23, 2009
- 11
I have a 40hp Johnson, I believe it's a 1963. It has a starter motor, but basically no other wiring to speak of and no solenoid. I have been messing around with it to see if it is worth doing an overhaul...to start the motor I have just been using jumper cables (pos. to the starter, neg. grounded to the lower motor cover) The stater motor will start and turn the flywheel fine the first time, but then I will try again and nothing...I usually wait until the next day and it will work once, than not again. Any ideas what might be causing this? Also any suggestions on wiring an old motor like this from scratch? (i know this is kinda broad)
thanks for any help
thanks for any help
