Starter not engaging
Capt dave 258
Just picked up a 1984, Johnson 150hp that hasn't been running in 5+ years. Hooked up jumper cables from a battery directly to the starter and ground. Sprayed the bendix shaft with spray oil and silicone. The bendix initially engaged with the flywheel but would do so slowly, not enough to start the motor. Took the starter off and jumped it and it seemed to spin with high rpm's. Put it back on the motor and cannot get it to engage with the flywheel. It just spins freely at a high rpm rate. Thoughts on why it won't engage with the flywheel? Thanks as always!
Simple to take starter apart for inspection / new brushes.----Do an ohm check on armature.---Should read infinity.
If you hook up the jumper cables backward, the motor will spin the wrong way and not engage the bendix.
Capt dave 258
I'll take the starter apart and do an inspection. The cables were not hooked up backwards. Thanks for your replies. I'll keep you updated.
If it is a permanent magnet starter, it must be put back together with the magnet in the same orientation, or it will run backward. It makes sense to match mark the ends to the center magnet.
Capt dave 258
Found the issue. The battery cables were reversed. The engine side of the positive cable was black in color and the negative side was white with a red band at the end. Previous owner spliced and taped them that way. Not sure why. Pulled the cables completely out for inspection and discovered it. Thanks Chris 1956 for pointing me in that direction. Old lesson learned about assuming. Thanks to all.
Easy test. Put voltmeter with battery in DC volts setting. Read voltage. Start motor and set to high idle. Read voltage again. Voltage while running should be higher than voltage not running.
Also, with engine running, set voltmeter to AC voltage and read voltage at battery. If you read any AC voltage, suspect damage to voltage regulator or rectifier (whichever you have).
