mia248vista
Thread starter- Joined
- Jun 9, 2008
- 44
Hi All,
2003 5.0 Volvo Penta GXi-B
DPS drive
I went to start my engine yesterday and was not able to get it started. There was no power to the starter.
I did have power to everything else, horn, lights, gauges etc. The fuel pumps primed up when I put the key to ignition. I got the 2 beeps I normally get just before turning the ignition to the start position. I could hear a slight click (solenoid?) when I turn the key to the start position but NOTHING to the starter.
The batteries are just over a month old with a couple of perfect outings under the belt.
I did play with the key several dozen times and at one point got the starter to turn w/ plenty of juice and start the engine.
I followed the troubleshooting guide posted by Don S. posted here (http://forums.iboats.com/showthread.php?t=167035)
Well it looks like its my starter or the starter solenoid that is bad. I performed some test and was able to get power all the way to the starter solenoid (terminal B on Don's diagram). The connections were corroded so as i tried to take them off when part of the solenoid broke off.
So I guess it is time to pull the starter. My Seloc manual shows the screws on the side of the starter, however they are not there. Anyone know how to get this out? What other parts need to come off to get to this?
Also do i need to remove the starter if it turns out the problem is just the replacing the solenoid?
DPS drive
