Starter issue
venture1200
When I start my 40hp Evinrude OB TE40ELETB on occasion the starter gear spins but will not engage the fly wheel. A simple tap on the gear will engage it with the fly wheel. Does anyone know if it's the starter or the solenoid that I need to replace or something else.
Any advise would be greatly appreciated.
Dave
D
DJ
Guest
Re: Starter issue
Disconnect the battery.
With your fingers, walk the starter pinion (gear) up the shaft in the opposite rotation of the starter rotation. Apply a very light grease to the shaft.
In addition, remove the negative battery terminal from the engine block. Clean thoroughly and reattach.
Reconnect the battery.
