countryboy4ever88
Thread starter- Joined
- Nov 16, 2009
- 1
I have a 4.3L GS Volvo Penta Motor. Boat Was Starting up fine till the starter went out in it. I Brought the Starter to a Starter Shop and had it tested. They said The solenoid was bad. I went ahead and bought a whole new starter and solenoid from the starter shop and put it back on the motor. When I started it back up it started to turn over then made a loud Grinding/Clunking noise. I brought the starter back thinking it might be the wrong one he gave me a Different started and the same thing happened. It will start to turn over then Grind and bind up. I turned the pulleys and made sure all the teeth where on the flywheel. I tryed to Shim the starter down but it just made it worse. I Did buy the starter from an Auto starter shop.Should I buy one from Volvo or might something else be wrong? Please Help!!
