Starcraft I/O to outboard and restoration
dafishiemon
I've been looking at threads on here for a while now. Just thought I would start thread and post pictures of my Project. Tell me what you think. Thanks...
bob johnson
re: Starcraft I/O to outboard and restoration
I think you need to focus the camera a lot better, or maybe put film it in............looking forward to it, as I am doing the same thing...bob
dafishiemon
Trying to post pictures i dont see upload link for pictures.?
dafishiemon
Re: Starcraft I/O to outboard and restoration
Woodonglass
I'm wondering what that big square hole in the transom is for??? I'm also wonderin if you are planning on putting in some Knee braces and what size motor you're planning on hanging on her?
jasoutside
Howdy, what kind of wood are you using back there eh?
dafishiemon
Have 2 knee braces cut out of 3/16 aluminum and a 24x24 piece of 1x4 aluminum to mount to transom bolted through to 80hp mercury. And tie other end to stringers. Got more pictures will post tonight. Square hole is for gas fill.
dafishiemon
dafishiemon
Two pieces of three quarter inch plywood lanated together with fiberglass resin in screws
jasoutside
Hmm, kinda looked like pressure treated, unsealed.
I'm looking...
It sorta looks like you sunk rivets all around the old stringer drive cut out, is that right? So are they kinda digging into the backside of your transom?
dafishiemon
No rivets diging into transom have piece of aluminum cut to fit around rivets and sandwiched between transom wood and transom aluminum
dorelse
How are you planning on building the splashwell?
dafishiemon
I'm going to fabricate a cardboard template for the splash well
Cut to pieces out of aluminum and have them bent and rivet amd 5200th together
dafishiemon
Trying to choose between noodles and pink insulation closed foam
dafishiemon
Also looking for convertible top That snaps to top of glass. Also the existing paint can i just scuff and repaint?
