Starcraft Titling/Custom boat
My title is a bit vague but I was hoping someone could answer a question for me or give me some advise.
I recently acquired an 18ft Starcraft Holiday. It is titled (supposedly) but I am waiting on getting it from the original owner. According to the hull sticker, the last time it was registered was in 1975... the hull is in excellent shape but the interior is shot (was never covered).
I bought the boat for a school project. I am in my senior year studying mechanical engineering and I wanted to design a jet boat using jet drives from a pair of jet skis. The jet skis are a pair of 110 hp engines that will provide the forward thrust. I know these boats are only designed for 120hp (according to the USCG plate on the boat) but jet pumps are axial flow propulsion units that transmit the forward thrust in a horizontal line. This thrust is transmitted to the hull which is capable of withstanding much more power than the transom mounted Outboard than it came with.
So, with my new design, I will be exceeding the hull rated hp and also be using a different propulsion setup. Does this make the title/ USCG plate with the serial number void? If so, I how do I go about getting a new registration for it? I have found the USCG builders workbook but I would like to use the original title if possible but I am having trouble finding anything about repowering/hp ratings.
This is my first boat build so pardon my ignorance.
Thanks for the help! I will start a thread once the design and build starts. Figured everyone would enjoy it. Hopefully no one will be upset with my cutting
