Starcraft chieftain 21 Restoration Project
johnnyCYD
Wow! Look at those seats! Absolutely amazing. :eek:
Actually i think that they never been used.Chair use a pole to stand on it....but there is no mark. Although that pole do not fit , because is too high. Below the chairs , are the fuel tanks the aluminium pole should be cut 10-11 inches to fit !
GA_Boater
The seats probably look better than the Admirals shoes. No scuffs and her shoes have scuffed soles.
:behindsofa:
Did you break the law by removing the tag or did the staples rust away? LOL
johnnyCYD
Took the back seats for cleaning! GA_Boater is right, 90% of the staples are rusted !
Made some new pictures inside the boat, but needs resize first !
GA_Boater
Check the staples holding the cover to the seat base. If the label staples are rusted, the ones for the vinyl are also rusted. Some re-stapling is probably needed so the seats don't fall apart.
Still - The vinyl looks brand new!
johnnyCYD
Can someoane tell me where those pieces are from ??
Watermann
Not a normal Chief piece I recognize, that looks like a track for some sort of add on would be my guess.
johnnyCYD
Can a friend who owns a 71 Chieftain 21' post some pictures with the fuel and water inlets, and step pads? i Manage to found some hardwere, but i want to be sure how the originals look like! Thanks
johnnyCYD
Thanks Kcassells, i've been searching , but no luck for goo pictures
If anyone can help me with pictures of rear cleats and fuel inlets ...Found the rest of them
