Starcraft '73 16' Holiday (refurb by relative newbies)
HI ALL! Finally getting back to the next phase of the rebuild on this. Looking for some further insite on replacing FOAM under the flooring. Someone had previously mentioned using 1/2 rigid foam from HD or Lowes. Any other info on this ? Should we also consider adding any expanding foam or anything like that? We are wrapping up flooring rebuild and Gluvit. Any help would be great.
BWR1953
This is how I did it on our Kingfisher. We used 3/4" rigid foam because that was the only size available in our area. Larger sizes are made and might be available to you.
Watermann
Stacked in on edge is how I did my SN.
pckeen
Did a much smaller boat, stacking on edge as well. You don't need to glue the pieces together, and when you put it in place, you'll find there will be a small gap at the bottom which will let water flow into the bilge.
