Dennisjr13
Thread starter- Joined
- Jun 5, 2008
- 7
I have a 1994 18ft Sea Ray with a Mercruiser 4.3L V6 (2bbl carb and thunderbolt ignition) and Alpha One Gen II outdrive.
The engine will run for 15-20 seconds at idle in nuetral, but will then stall. Revving the motor to 2-3000 RPM did not help as it would still stall after 15-20 seconds. It does not run rough, and ran fine last season. It was winterized with new fuel/water seperating filter, carb inlet filter, and fuel stabilizer.
The electronic fuel pump was replaced approximately 5 years ago. Replaced the lower unit shift cable last year (see this thread from last year), as well as the plugs, wires, and distributor cap/rotor.
Is it a fuel problem?
