stabilizing the motor
js75495
just bought a Lowe Stryker SS with a Mercury 30 efi 4 stroke with PT. Dealer said dont need a "transom saver" just raise the motor and use the clips. This worked fine but the motor, after a good bump on the highway, moved sideways abruptly. How can I keep the motor centered and not have the steering move during trailering ?
robert graham
Re: stabilizing the motor
Get the Transom Saver and use it, make you feel more happy and secure while trailering.
Fed
I lay my motor to the side right from the get go and hope it doesn't swap sides on a fast corner.
ezmobee
Ditto. I liked my transom saver primarily because it prevented much of the side to side movement as well as the bouncing up and down.
sublauxation
Same here, I got the transom saver primarily to keep the motor from turning side to side. I used to bungee cord the stearing wheel and that worked too, but I prefer the transom saver.
SteveRoss
Been wondering about this for a while. I have a little SeaArk 14 foot all welded aluminum boat with a Honda 15 4-stroke on the transom. When towing it, should I leave it in the down position, or raise it to the max?? Which would cause less wear and stress on the transom ? Thanks
Steve
ezmobee
Steve
On a small boat like that I'd tow with it down (as long as the skeg is a long way from the ground) and just strap it to prevent side to side movement. A small transom saver wouldn't be a bad ideal though.
