Sta-lok reuse ?
Lee Strong
Hello World! <br /><br />As I begin to replace my standing rigging wire, and try to reuse the existing Sta-lok end fittings, a couple of questions came up:<br /><br />1 - Is there a standard procedure or tool for the extraction of the wedge? I am considering a screw extractor, but it might damage the socket.<br /><br />2 - Can I reuse the former, or do I need to replace that too?<br /><br />I have also sent this question to info@stalok.com. Their standard installation procedure is for a new fitting -> <br /><br /> http://www.stalok.com/index1.asp?fitting=True <br /><br />Thanks!
flashback
Re: Sta-lok reuse ?
Years ago I used to rig sailboats and if i remember, you need to replace the wedge and the former. used to soak it in penetrating oil then use a hammer and drift to get the old wire out...I think if you are replacing your rigging, it would be better to swage new fittings rather than use the stayloc...........
