Sputtering
SweeperForce
I've been searching on here for a while and can't find a answer. While cruising around at wot my motor runs great but while I pull it back to 1/2 throttle it sounds horrible for about a full minute then it mellows out. It sputters and revs. It will keep doing that for 1 minute. I considered changing my spark plugs, but there only 2 years old with less than 50 hours on them. I should do a compression test, I just need to buy a gauge. I don't know what else can be done to fix this problem.
Thanks,
Tom
jerryjerry05
Re: Sputtering
Probably not the plugs.
Sounds like the fuel recirculation system isin't keeping up with the return??
Linkage all adjusted right?Linc and sinc?
And shame on you!!! :) AS much work as you've done and don't have a comp tester??? :)
