Spun hub 1985 johnson 15 hp
Jefffrey
hello, i think i have a spun hub on my prop. cant get the prop of.f Is there a prop puller idea to get it off myself? Any help is appreciated. thanks Jeff
Honorary Supreme Mariner
5/16" threaded rod.-----Make a J-hook and slide hammer.
Block of wood and a hammer might do it.----Or run to your local boat shop , they will likely have it off in a heartbeat.
achris
More fish than mountain goat
I have a 1985 Evinrude 15 hp that is by all accounts free-wheeling on me. It did it two times at max speed. It fired up and there was a deficiency of forward movement like a stuff slipping or the prop not turning. I let off the choke right away and the issue stopped and everything worked fine immediately. Any ideas. I keep everything lubed well-oil fittings and stuff oil.
Please don't hijack other members thread's. If you have a question, start your own thread.
Chris.
iboats mod team.
