baytonemus
- Jun 23, 2010
- 217
I've read several of the really helpful threads about how to replace and repair an old cable, pulley, & drum steering system. I'm about to start in on that, but I've got a couple of questions about the springs used in these systems. Somewhere along the way these springs in my boat must have been abandoned.
My dad installed and repaired a lot of these back in the 50s & 60s when he and my grandpa had a Johnson/Evinrude and Crestliner dealership. He says that they were usually installed between the motor mounting bracket and the two pulleys at the center rear of the boat. However, all of the pictures I've seen on this forum show them mounted to the inside of the side walls somewhere and at least partially concealed.
I've found these springs available through iboats, but I can't quite tell how they would be connected on the back end. Is there a loop that will be drawn out the end with the hooks, or would you just attach one the hooks themselves?
Thanks!
Thanks!
