Sport Jet 175 x2 with low compression
I will read up on my settings my carbs.
I was lied too! I was told those testers were worthless.
No matter what, I am going to use an ir thermometer.
If some of the cylinders are not firing, that would be an obvious reason the rpms are low.
here you go
8 in one adjustable gap tester https://www.amazon.com/CDI-Electronics-511-9766-Enclosed-Adjustable/dp/B002IZFSSO/
the single that I have been using for decades https://www.lislecorp.com/specialty-tools/ignition-spark-tester
your manual will tell you specifically the minimum gap the spark must jump. for example, some motors must jump 7/16" or 1/2"
rossman21
Thank you!
I have never heard of these products - I thought you were talking about a procedure to do on the engine...
