Beefer
- Aug 4, 2008
- 1,737
Just curious if you guys think I'm seeing the speeds I should out of my boat. 1994 Bayliner Capri 1604 Sportsman (Bowrider), dry wt (per NADA Guide) of 1350lbs. 1994 Force 70HP o/b. I'm seeing 28-30mph (GPS) at WOT with 2 adults and one skinny 7 year old, 12gals of fuel, and not much in the way of gear. For some bizarre reason, the boat came factory without ANY guages, no less a tach, so I can't say what my rpm's are. I'll be installing a tach within the next week or two. As far as the prop, I know NOTHING about it, but I would guess it is the original.
If any of you guru's and guru-wannabe's can make a guess, I'd appreciate it.
