Re: speed and dept
Could happen for a couple reasons. One, the transducer in the water isn't designed for high speed applications but if it happens around 10mph, not likely.
Two, it could be improperly mounted or positioned (Most have a bracket that releases if impacted to prevent damage.) If it came unconnected, it could simply be 'flapping' in the water giving insane depths (300-500ft)
Lastly, you have a faulty transducer or even a receiving unit.
Check #2 first and see if that is the problem. Had it happen on several boats I've owned or been in. Hopefully that's the issue.
