spark plugs
angler00
any suggestion's?? have a johnson model j150vxsss year 2000. plugs in it are champion QL78YC
boat run's fine but would like some info.. (just asking) is there a different plug to run with this motor.
RogersJetboat454
Re: spark plugs
Why fix what isn't broken?
That engine was designed to use those particular plugs. What do you hope to accomplish by running a different plug?
angler00
Re: spark plugs
not trying to accomplish anything, just asking if there is any different plugs to run
tired to run champion in my harley and found out that is a BIG NO. just getting all the info I can
(newby on boats)
fishfeatures
Re: spark plugs
hate to butt in to this (i'm not hi-jacking honest) but I find it hard to get Champion plugs over here , does anyone know if there are an NGK equivalent and if so are they recommended to run in OMC motors???
nwcove
Re: spark plugs
you can run any equivilent plugs you want to run......but you may not be happy with the outcome. stay with the recommended parts.
RogersJetboat454
Re: spark plugs
(newby on boats)
Pretty much since the dawn of OMC, Evinrudes, Johnsons, Gales have had Champion brand plugs recommended by the factory.
RogersJetboat454
Re: spark plugs
Well.... as bad as it sounds, you are hijacking, but if you plug your engine info into here;
http://www.ngk.com/Default.asp
It will give you the NGK equivalent, that may or may not run as good as a Champion. For more info I would start my own thread if I were you.
nwcove
Re: spark plugs
if i were you, id look into bosch plugs ( but can you still get them?)
Haffiman
Re: spark plugs
You may run an alternate brand, but be sure to stay away from anything with 'R' in the spec. But as said above, preferably stay with the original Champion.
angler00
Re: spark plugs
Thank you, not planning to change anything just wanted to see if there was anything different..
this is all new to me just trying to get all the info I can.. like I said tried champion in my bike
went on someone's word and found out they didnt work.. 50 miles down the road they were shot
again thanks for info.. I'm sure down the road I will be asking alot of question they might seem to be stupid question to you guy's
but I will ask them any way thanks again
Re: spark plugs
Fish, the cross reference from the Champions to NGK is BPZ8HS-10
