1970-72 mercury thunderbolt 800/80hp sn:2886778 no spark
mercthunderbolt123
hello there...... i have a few questions for anyone who can help me?
ok well ibought the motor from someone who said there was no spark. the first thing i did was replace most of the wires as i knew they would be corroded and i attemped to start it again and once again no spark. no w i was told the engine was stored for a number of years so i was thinking i have to do the magneto and clean it up does anyone else have any options i also checked the distributor cap and everything looked fine???
rtpassini
Re: 1970-72 mercury thunderbolt 800/80hp sn:2886778 no spark
hows your battery?
go to the faq forum on here and look up some of the how to's
mercthunderbolt123
the battery is fine i have an elimnator booster pack trying to start it
Moody Blue
No spark
- check that there is 12V on both RED and WHITE terminals of port side of switchbox with key in run and start position
- battery must be in good condition. A weak battery will not start this motor. MUST be 9V minimum on those terminals when cranking.
Here are a few pages on troubleshooting the battery CDI ignition systems
http://outboardparts.com/mercury/troubleshooting/troubleshooting8.htm
http://www.boatpartstore.com/page18.asp
http://www.maxrules.com/cdi/TroubleshootingGuide.pdf
(scroll down to Merc Battery CD ignition system)
mercthunderbolt123
i treid today and i am getting 12v off both terminals and i followed the troubleshooting and didnt work either. i think it might be the coil any suggestions....need help!!!!!!!
mercthunderbolt123
sorry i mean i am reading 12v from all terminals
mercthunderbolt123
the terminals that are supposed to have 12v have it is what i meant
i just replaced the switchbox, checked the coil and i am still getting no spark i found out the rectifier is all messed up the seal has been broken and it is corroded will that cause no spark????
The rectifier plays on part in the ign system on that motor. Ohm out the coil. it should have 1 ohm or so on the primary and several hundred ohms on the secondary. The plug and coil wires screw into the dissy cap. They pull out of the coil.
Run the Battery CDI test to see what is wrong, but if you have a known good switchbox, and good wiring, it is either the coil or the dissy trigger.
