spark plugs
tko1802
Spark plugs are getting wet once we fire up the engine dont know what to do need help asap?
tx1961whaler
Re: spark plugs
Wet with water, gas, or what?
Please be more descriptive. Nobody can help you if you don't fully describe your problem.
JB
Re: spark plugs
How are you finding out that the plugs are wet when the engine is running?
Yeah, a stupid question, but that is what you said happens.
If the plugs are wet when you shut her off, that is normal. The engine continues to pump fuel into the cylinders after you shut off the ignition and until she stops. That leaves wet plugs.
tko1802
Re: spark plugs
we can only get the engine to start up once and that is when the spark plugs are dry and once it starts up it runs for a little and shouts off and we cant start it back up and we saw that the spark plugs are wet with oil.
JB
Re: spark plugs
That is a bit more of the story. Is there more that you haven't told us yet?
tko1802
Re: spark plugs
the alarm was going off at a rapid speed but the motor wasnt even on it was going off when we were trying to start it and we got it to start for a little but we had to keep priming it to stay on but it didnt sound right
tx1961whaler
Re: spark plugs
A guess:
Air leak in the gas line causing the VRO system to go crazy and over-oil.
Just a guess.
