What is the recommended gap for this motor?<br />Running Champion QL77CC plugs.<br />Thanks!
C Cane Pole Recruit Joined May 31, 2005 Messages 2 Jun 1, 2005 #1 What is the recommended gap for this motor?<br />Running Champion QL77CC plugs.<br />Thanks!
P Perfidiajoe Petty Officer 1st Class Joined Apr 1, 2005 Messages 378 Jun 1, 2005 #2 Re: Spark Plug Gap? - '97 Merc 250 EFI I have a 1995, EFi that takes the same 6 plugs, the book says .035 for the champions. If you run the NGK's the book says .040 Good Luck Joe
P Perfidiajoe Petty Officer 1st Class Joined Apr 1, 2005 Messages 378 Jun 1, 2005 #3 Re: Spark Plug Gap? - '97 Merc 250 EFI I have a 1995, EFi that takes the same 6 plugs, the book says .035 for the champions. If you run the NGK's the book says .040. Should be the same on the 1997. Good Luck Joe Sorry for the double post,
C Cane Pole Recruit Joined May 31, 2005 Messages 2 Jun 2, 2005 #4 Re: Spark Plug Gap? - '97 Merc 250 EFI Thanks, that's what I thought.
