Spark Plug Gap? - '97 Merc 250 EFI
Cane Pole
What is the recommended gap for this motor?<br />Running Champion QL77CC plugs.<br />Thanks!
Perfidiajoe
Re: Spark Plug Gap? - '97 Merc 250 EFI
I have a 1995, EFi that takes the same 6 plugs, the book says .035 for the champions. If you run the NGK's the book says .040 Good Luck Joe
Perfidiajoe
I have a 1995, EFi that takes the same 6 plugs, the book says .035 for the champions. If you run the NGK's the book says .040. Should be the same on the 1997. Good Luck Joe Sorry for the double post,
