spark plug fouling
cheapster
I have a 35 horse chrysler and i keep fouling the same plug every couple of trips 2 the lake . I checked compression one cylindar read 100 psi the other was about 105 . It burns through the gas also, I would say it burns 4 gallons of gas n about 8 miles . Any suggestions ?
john from md
Re: spark plug fouling
If you haven't rebuilt the carb and fuel pump in a while, it is always a good idea. I also suggest that you swap the coils and see if it moves. You could have a coil going bad.
John
moparman
any chance the choke could be hanging slightly closed? This would explain some of your problems that you have ,and very easy to check for this condition. just my two cents worth. MOPARMAN
cheapster
I looked 4 a carb kit Tilston wb17c527 no luck do they make new carbs u can bolt on ?
