Spark + fuel+ compression still won't start!
Green Giant
I have a 2007 24 hp 4 stroke efi mercury that has run flawless it's whole life until yesterday. It started perfectly and idled great on the way out of the marina then I went to get on plane and it sputtered horribly. I tried to let it run its self out of it for a moment then decided I need to get back to the dock. I made it 50 feet from the dock and couldn't get it to start no matter what. I checked and I have spark, compression and fuel. I'm at a loss from here!
Green Giant
Re: Spark + fuel+ compression still won't start!
I should add that I sprayed a little starting fluid in the cylinder to bypass the fuel system and still wouldn't fire. The spark I do have doesn't seem to be as strong as it should be as we'll.
JB
A 4 stroke also needs precise timing of the valves, injection and ignition. I don't know your engine, but if there is a belt driving the cam and/or ignition it may have slipped.
Rodbuster
Did you try unplugging the kill wire ?
Black with yellow stripe.
Green Giant
I'm not 100% sure but I think it's all electronic on this motor?
Green Giant
I have not, I did a quick look for it but didn't see it. I bet I can find a diagram some where. I will try that and post the results. (Should I try to do a normal start routine with it disconnected ?)
Green Giant
I'm starting to wonder if the fuel is actually making it all the way to the cylinders
Green Giant
Somebody locally thought it would be 1 or a combination of power pack, regulator and or "trigger".....?
Green Giant
I've just about got this one by the balls boys. Long story short the "good fuel" I was trying to get in the cylinders wasn't making it because the fuel system was full. I'm working on getting the bad fuel out but I at least have it running. Ruff but running at least.
