SP drive slips out of gear
knotso
I have a houseboat with twin AQ151c with SP drives (circa 1989). Drive will not engage forward unless I keep pressure on the lever and then apply throttle. Once engaged the drive will stay engaged until I reduce throttle at which point it will slip out of gear. Any ideas on what I should/could be checking while the boat is in the water and before I go through the haul-out expenses. Thanks.
Don S
Re: SP drive slips out of gear
You need either a lot of adjustment, or most likely, new shift cable. When the cables get worn inside, they won't reach both gears.
knotso
I'll try the adjustment route first (which really means get someone else with experience). Thanks very much.
