giorgos8888
Thread starter- Joined
- Jul 28, 2009
- 9
Hey everybody !! Very nice and interesting is this Forum and i stay for a while but at least i 'm sticking for hours !! the last days i found out it.
I own a Force 90 hp i think model of '93 and after 10 years and enough miles the left bracket cracked starting exactly from the up holding bolt and going straight up for 8 cm length .Near the bolt ,opening of crack is 1 mm and die away till the 8 cm lenght.
Here in Greece couldn't find a new one and one engineer told me to fix the same with argon sticking and a second one told me that only the surface will be stick and better he will search his old spares in his stock and to replace if he find otherwise to stick it.The first one doewn't want to take the job because he says is hard to remove the four bolts (2 horizontal and two vertical to remove the bracket) and has to cut them because of salt and to replacce with inox (sell by metre and not the special of Force cause does not exist in the mmarket)and the second said is easy to remove the bolts but don't wants to tell me what costs before he will search his spares????????
An advise please ??!!
